It is currently Sun Dec 17, 2017 9:02 am
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Squeaky brakes
PostPosted: Fri Oct 14, 2011 4:58 pm
can i tap into the collective wealth of knowledge and ask how i can get rid squeaky front brakes. and possibly, what causes it.
so far i have had the bike serviced, including replacing pads. The tyres have been changed. I have smeared copper grease on the rear of the new pads. i have even tried a few "hard" braking exercises. But they still sound like a knackered old London cab.
Any advice, oh wise sages?
The world is comprised of three types of people - Those who make things happen. Those who watch things happen. And those who ask "What the f*ck just happened there?"
 Post subject: Re: Squeaky brakes
PostPosted: Fri Oct 14, 2011 6:23 pm
what bike tricky :?:
Blue is best just ask anyone !!!!!!!!!!!!!! But Black is growing on me
PostPosted: Sat Oct 15, 2011 12:40 pm
Triumph Speed Triple - the new shape that they are still making in White :wink:
PostPosted: Sat Oct 15, 2011 6:44 pm
all i can think of is that a piston is sticking
if you paid to have it serviced i would take it back.
if you want to have a go yourself, remove the calipers and pads and with a soft tooth brush and weak solution of washing up liquid clean the pistons.
if you push one in the other in the pair should move outwards and vice versa. clean off any build up of crud dry and reassemble.
good luck
PostPosted: Sun Oct 16, 2011 9:01 pm
oh charming. that hurt me.. i got a knackered old London cab. my brakes dont squeek, but i do a bit. :roll:
there goes your free trip to the airport wen u go on holiday. :wink:
"You don't stop laughing when you get old, you get old when you stop laughing
But there always is a but..
PostPosted: Mon Oct 17, 2011 10:23 am
Suffered for months myself, cleaning the pads, copper spray grease the works..
Mot time having a moan to the mechanic about it and was corrected about what is a common misktake..
with the pads out and de rusted - add a light smear of 'proper 'copper grease (from tin or tube not spray) to the back... but also the sides as it is the sides rubbing in the caliper that makes the noise.. i questioned the posibility of the grease getting on the pads :oops: :oops: , only to be told a smear of thick grease on the metal parts only will not melt or run on to the pads.. :wink: :wink:
This done i have not had a squeak front or rear since - give it a go.. and hopefully no more squeaks for you either
PostPosted: Mon Oct 17, 2011 11:42 am
Oh crikey! i don't want to start making enemies of London cabbies.
What i mean is - the minority that do squeak, tend to make teeth rattle and ears bleed. I'm sure your cab is a beautiful example, smelling of Nordic pine forests, and an absolute pleasure, nay, almost an honour, to be in the back of.:oops:
(is that enough back tracking?)
Anyway, that's this weekends job sorted. A bit of fettling with the brake cylinders. Thanks Rob
