Just a reminder that the AGT (Associate Group Training) for associates and Full Members(FTFM training) is on Sunday 6th March. We look forward to seeing you.
Note: Full members are welcome to come and participate in the RC talk then go for a ride - as pre-covid.
AGT's give you the opportunity to experience a different Observer for the day and meet with others in the group. There will be a short Roadcraft talk prior to allocations.
Guests are welcome if pre-arranged. Just let us know if you want to attend. Call Mick 07762 889408.
NOTE: Please ensure your motorcycle has a full tank of fuel, is fully legal for insurance, tax and MOT (if applicable) - no need to produce documents if you signed the disclaimer. And equally important that your machine has been POWER checked - pre-ride checks will be carried out by the Observer on the day. If any safety issues found then the observed ride could be cancelled.
Address: Beryl Platt Centre(formerly Longmeads House) , 12-14 Redwood Drive, Writtle, Chelmsford. CM1 3LY. Ride round the back to the left of the old building.
Time: Arrive 09:00 - Start: 09:30.
Note: If you've recently joined and not received your Roadcraft and Highway code, please let me know and I'll bring along. Or any questions?
Mick Hewitt 07762 889408
There's a charge of £10 for each participant towards payment for the venue etc. NO payment for the Observer for AGT training.
No need to book, just turn up on the day.
Please re-join EAMG for 2022 if not already done so.
PLEASE NOTE: IF WEATHER CONDITIONS UNSAFE TO RIDE THEN WILL BE CANCELLED BY 6PM SATURDAY.
The Training Team
AGT (Associate Group Training/FTFM) 6 th March 2022
