Note:
From August we’ve decided to go back to a booking-in system for Associates and FTFM (Further Training Full Members) – which was successfully operated during Covid.
Can all those wishing to attend please email:
mickhewitt39@hotmail.com / or text 07762 889408 confirming name and attendance for the next AGT – if circumstances change after booking then just advise. No problem.
This will help to ensure Observers that attend have a trainee to take out. Very frustrating for Observers when no one turns up! They're very keen to help you.
Thanks
Just a reminder that the AGT (Associate Group Training) for associates and Full Members(FTFM training) is on Sunday 7th August. We look forward to seeing you.
Full members are welcome to come along to meet and go for a social ride after Roadcraft talk.
AGT's give you the opportunity to experience a different Observer for the day and meet with others in the group. There will be a short Roadcraft talk prior to allocations.
NOTE: Please ensure your motorcycle has a full tank of fuel, is fully legal for insurance, tax and MOT (if applicable) - no need to produce documents if you signed the disclaimer. And equally important that your machine has been POWER checked - pre-ride checks will be carried out by the Observer on the day. If any safety issues found then the observed ride could be cancelled.
Address: Beryl Platt Centre(formerly Longmeads House) , 12-14 Redwood Drive, Writtle, Chelmsford. CM1 3LY. Ride round the back to the left of the old building.
Time: Arrive 09:00 - Start: 09:30.
Note: If you've recently joined and not received your Roadcraft and Highway code, please let me know and I'll bring along. Or any questions?
Mick Hewitt 07762 889408
There's a charge of £10 for each participant towards payment for the venue etc. NO payment for the Observer for AGT training.
Please book-in (see above).
Please re-join for 2022.
The Training Team
Associate Group Training(AGT)/FTFM 7th August, 2022
