Associate/Member Social ride 23rd January, 2022
January's social ride will be to the Hungry Stag Cafe Bury St. Edmunds (IP30 9FX).
Destination: Hungry Stag Cafe.
Distance: About 110 miles total.
Finish at MacD Regiment Way for coffee - about 14:00.
See you there.
Kitchenman
Re: Associate/Member Social ride 23rd January, 2022
Post by Kitchenman »
wimping out again
