March's social ride will be to the Scotsdale Garden Centre, Fordham (CB7 5LQ)).
Destination: Scotsdales Garden Centre, Fordham (CB7 5LQ).
Distance: About 110 miles total.
Finish at MacD Regiment Way for coffee - about 14:00.
Associate/Member Social Ride 20th March, 2022
Re: Associate/Member Social Ride 20th March, 2022
Just wanted to say thank you to Mick and Alan for a lovely ride out today, and for organising the great weather too
- peterbennetive
Another good ride with some great people. Thanks Mick and Alan.
Yes, a good day had by all. Good to see you.
