Associate/Full Member Social Ride Sunday 26th June 2022
Apologies for late posting.
June's social ride will be to the Rushbrooke Arms Sickelmere, Bury St. Edmunds (IP30 0BU) - using the back roads.
This is a relaxed ride keeping to the speed limits.
Note: Colin is also running the Full Member ride this day from Sainsburys - my ride will park at the back of the car park, Colin will park on left hand side.
Destination: Rushbrooke Arms
Distance: About 110 miles total.
Phil Ruddock
Re: Associate/Full Member Social Ride Sunday 26th June 2022
Post by Phil Ruddock »
Thanks for the ride today Mick & Alan. Great route. Really enjoyed it. 🤗
Thanks Phil. Really enjoyed your company.
