Associate/Full Member Social Ride 14th July, 2024
Posted: Thu Jul 04, 2024 10:07 am
July's social ride destination is the back roads to Hearts Delight Garden Centre Cafe - Manningtree, CO11 2EF.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first. Thanks.
Distance: About 110 miles round trip - Approx.
Mick, Alan and ~Dave - please add mobiles to your contacts.
