Associate/Full Member Social ride 13th July
Posted: Tue Jul 01, 2025 11:09 am
Hi all
Please join us for July’s social ride - destination Dobbies at Shepreth, Royston. SG8 6RA.
Note: Due to the heat the ride will total 85 round trip.
Note: Please make sure your membership is up to date before joining the ride.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 5pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they let me know. Thanks.
Full tank of fuel - fuel available Sainsburys but no toilets. Toilets are at the BP garage Boreham interchange.
Distance: About 85 miles round trip - Approx.
TRANSMISSION - engine oil also lubricates gearbox - in nearly all cases. CHECK YOUR CHAIN - IT MUST BE LUBRICATED AND ADJUSTED CORRECTLY.
Mick, Alan and Dave - please add mobiles to your contacts.
