A Warlock built for the hardest Diablo 4 runs starts with one big question: what can carry the critical-hit engine without forcing every other slot into the same job? Players checking D4 items often look straight at The Grandfather, and for good reason. At 900 Item Power, this Ancestral Mythic Unique two-handed sword brings 4,659 Damage Per Second and up to 33.8 percent Critical Strike Chance. That single stat line frees up a surprising amount of room elsewhere. You're no longer patching weak chance rolls on every ring, glove, and amulet.
The weapon does more than raise damage
The Grandfather earns its place because it helps the Warlock stay in the fight. More than 6,550 Maximum Life gives you a bit of breathing room when a Tormented boss throws out overlapping attacks. Its Lucky Hit resource return also matters. Hellfire, Wrath, and Dominance skills can drain a resource pool fast, especially during long boss phases. A sword that supports your rotation feels better than one that only makes the damage number bigger.
Prioritize Critical Strike Chance from the weapon first.
Use other gear slots for Willpower, life, and damage layers.
Keep enough resource recovery for repeated high-cost casts.
Putting the critical package together
Once the weapon is doing the heavy lifting, the rest of the setup can chase meaningful breakpoints. A Warlock near 83.4 percent Critical Strike Chance will see critical hits on most casts, while 1,442.8 percent Critical Strike Damage makes those moments count. Add 12.5 percent Attack Speed, 72.5 percent Vulnerable Damage, and 160.0 percent All Damage, and the pace changes. Packs disappear quicker. Elite fights stop feeling like a slow grind. Willpower should still be a major focus, with many serious setups pushing past 2,300 to improve skill output and healing.
Defence still has a place
It's easy to get carried away by huge yellow damage numbers. Then a high-tier Nightmare Dungeon reminds you why defence exists. Fire Resistance above 9,300 and Toughness over 450,000 give this kind of Warlock a sturdier footing. That resilience fits the class fantasy, too: an experienced demonologist calling up Hellfire while controlling summoned forces. The purple shine of a Mythic weapon works nicely with that darker look, but the real appeal is being able to keep casting when the screen gets crowded.
Building around the playstyle
A strong Warlock isn't just a collection of peak rolls; it's a character whose weapon, resource flow, critical damage, and defences all pull in the same direction. Players can test small changes, compare clears, and settle on what feels right for their own rhythm. As a professional platform for players looking to buy game currency or items, U4GM offers a convenient option, and you can purchase u4gm D4 items to round out a preferred setup while keeping the focus on the fights ahead.
