Associate/Full Member Social Ride 24th July 2022
July's social ride will be to Roots and Shoots Garden centre near Stowmarket.
Destination: Roots and Shoots (IP6 8RR).
Distance: About 115 miles total.
John Tipper
Re: Associate/Full Member Social Ride 24th July 2022
Post by John Tipper »
Hi Mick,
Many thanks for organising the Social Ride today. @ 30 degrees, it was quite hot but Roots and Shoots Garden Centre was excellent find, we'll be visiting them again. A great bunch of riders but shame about the massive tractor and slow hay cart that reduced the group's pace to a crawl.
John and Audrey
Doug merrygold
Post by Doug merrygold »
Hi mick thanks for a great ride ad route good to see old and new faces and many thanks for Alan for back marking all the best Doug Maz.
Yes, good day although some agricultural obstacles. Bit hot but enjoyed the company.
