Note:
From August we’ve decided to go back to a booking-in system for Associates and FTFM (Further Training Full Members) – which was successfully operated during Covid.
Can all those wishing to attend please email:
mickhewitt39@hotmail.com / or text 07762 889408 confirming name and attendance for the next AGT – if circumstances change after booking then just advise. No problem.
This will help to ensure Observers that attend have a trainee to take out. Very frustrating for Observers when no one turns up! They're very keen to help you.
Just a reminder that the AGT (Associate Group Training) for associates and Full Members(FTFM training) is on Sunday 7th August. We look forward to seeing you.
Please book-in (see above).
Please re-join for 2022.
Associate Group Training(AGT)/FTFM 7th August, 2022
